Old 11-Dec-2014, 8:07 PM   #1
Patrick
Freeport, TX area Antenna recommendation
Can you please offer some advice on an antenna to pick up the following stations from this area?
NBC – KPRC, Ch. 35
CBS – KHOU, Ch. 11.1
ABC – KTRK, Ch. 13
FOX – KRIV, Ch. 26.1
WB - KIAH, Ch. 39
This is for a business application and will require the signal to be split and distributed to 5 - Monitor/receivers with ATSC tuners that are approximately 100' feet away. We will be using Beldon RG6 Plenum cable to each monitor.
Report is here;
http://www.tvfool.com/?option=com_wr...d2437db3a42385
Thanks in advance for any help or advice you can offer!
Patrick
Patrick is offline   Reply With Quote
