First off, thank you everyone for your advice and help.
Last night, disconnected the Mohu splitter and amp, and attached directly to the tv and no difference.
WNYW 5.1 was very choppy as was 5.2. 5.3 WNYWDT3 wouldn't get anything and 5.3 WNYW SD (different frequency) was fine.
So, I simply deleted 5.3 WNYWDT3 off my list and only have one 5.3. Problem with that is on the Tivo guide, it doesn't pick up the 5.3 SD. Tried to record last night, and when I went back to check it out, it didn't record. Tested it again this morning by setting up a manual recording. I will see later.
Next few days, I will try to play with the antenna and try to get it to exactly 47 degrees. Closest I could get the other day was 49. Would 2 degrees really make that much of a difference, if I am picking up everything else that is at 47 degrees?
Anything else I can try?
