I am thanking everyone for their input. I am awaiting the arrival of a new Rotor that I ordered and an inexpensive compass (can't believe I've waited this long to own one). When these arrive, I'll quit stressing and re-establish my ability to tweak this issue from inside the comforts of my home.
Still find it strange that two has fallen off the reception since it is in the exact same line of direction as many of the Philly stations to my NE.
I'll provide an update, once my new rotor is up-and-running. (I had over-tightened the coax connection on the Eagle Aspen and snapped the mounts of that connector on the rotor circuit board. I attempted to get the right part and solder in a replacement but, never found the right configuration for the RG6 connector so I ordered a CM rotor.)
Regarding a meter on the TV, it has one but is visible only for those channels that are strong enough to be included in the auto-channel scan. This newer TV doesn't have an Add feature so I can't add Channel 2. to the channel line up unless signal strength is strong enough to be picked up.
Again, thanks for your inputs.
Winegard HD7084P antenna
ProBrand Int'l RTR100 rotor
Winegard Boost Pre-Amp
Viewsonics VSMA 601C-10R Amp
Samsung 55UH8500FXZA
