Old 9-Dec-2014, 11:33 PM   #28
Tim
Vinyl electrical tape will not keep moisture out of a connection. You will have better results using a mastic type tape such as Coax-Seal or Scotch 2228. I only use vinyl tape as a top coat to protect the soft tacky mastic tape from dirt and UV.
I highly recommend silicone fusing tape for sealing antenna connectors. I use it outdoors on ham radio antenna connectors and it provides a perfect seal without being sticky or tacky. After about 24 hours it fuses to itself and becomes one solid piece. You can easily slit it to remove it and it leaves behind no sticky mess. http://www.hamradio.com/detail.cfm?pid=H0-010683 It is also available at Home Depot, on eBay and Amazon.
