Old 9-Dec-2014, 6:02 PM   #20
The amplifier looks like the size and shape of a balun - maybe it's just the power injector, and the amplifier is actually in the antenna body.
Nope, that's the amp itself, it doesn't use a power injector in the coax line. It's powered from either a USB port or from a wall-wart that the USB-ended cable plugs into. You can always use the wall-wart to charge your cell phone if you supply your own cable, it's just a common 5V USB supply.
