Old 28-Dec-2010, 4:02 AM   #6
Originally Posted by Crawl View Post
right now i get 8.1,10.1,13.1,31.1,51.1 (virt)from the indoor Ant. She's after 40.1 (virt). If I do an outside antenna I'd probably hook it up to a 2nd TV set.
To be honest I'd like to get as many in that direction as possible
I do not see a digital station using 40.1 Virtual on your report, so I assume you are referring to WBGT-CA 40 real, an analog low power station affiliated with the 'MyNetworkTV' network.
If you are connecting more than one set, you will likely find a rotator a source of conflict when trying to view stations from different directions. I would use the larger Winegard HD7698 aimed to the SE and a two-way splitter (no amplifier). Use the analog signal from WBGT-CA to fine tune your aim, adjust for least snow and ghosting, the stronger digital stations should be well above the minimum level needed.
