Old 8-Dec-2014, 7:10 PM   #13
You should absolutely NOT be using two amplifiers. Heck, you don't even need one with signals that strong. Amplifying signals that are already strong is usually an open invitation to amplifier or tuner overload which results in LESS reception, not more.
If your Sky 60 uses the indoor amp that's white and cylindrical, be advised it's really not a very good amp (easy to overload, much higher gain than advertised, no filtering in spite of advertising), especially when compared to Jolt's older indoor amp that was in a black metal case. That's what happens when Walmart beats up on you to reduce costs.
