Old 8-Dec-2014, 5:16 PM   #10
coggsnyrnyg
Originally Posted by timgr View Post
I'd suggest you get a new, long cable and run your antenna directly into one of the TVs. The Tivo has a tuner that is receiving and storing the TV data. I believe the Tivo then streams the TV data to your TVs in its original form, where it is then decoded by your TV tuner (set to a specific channel?). So you have two tuners in the signal path ... unless the Tivo streams to the HDMI port or something like that.
Whichever, I'd eliminate as many variables as possible, then start adding stuff step by step.
Using the HDMI output of the tivo to the TV.
coggsnyrnyg is offline   Reply With Quote
