When using TV Fool, you can always enter your address. The best method is to click on "Online TV Maps" on the left, enter your address or zip code, click "Map this", then left-click and drag the teardrop icon to your location. Zoom in using the plus sign on the left side of the map. To move the map, left click on the map, hold the left click and drag the map in the proper direction. Once you reach maximum zoom, click on "Satellite" in the upper right corner and continue the process. When the teardrop in positioned correctly, click "Make Radar Plot".
