Old 6-Dec-2014, 4:55 PM   #7
You can try re-adjusting the aim of your antenna as described. If one of your TVs has a built in "signal meter", pull that up on channel 2 (if allowed) and tweak the antenna for best results on 2 without damaging reception of anything else.
Low-VHF is particularly susceptible to locally-produced local electrical noise that can't be mitigated, so don't be to surprised or disappointed if things don't turn out quite the way you want.
