Your report shows edge paths... you are over the hill from the stations. That means you will want to use an outdoor antenna, avoid the obstructions of your walls and roof.
Minimum antenna, an Antennacraft HBU33 or HBU44. A larger Winegard HD7697 or even HD7698 is not unreasonable.
The lager antennas and a rotor will give you the best line up, but the HBU33 aimed SE will offer a good channel selection.
