Old 3-Dec-2014, 7:41 PM   #5
timgr
If you want to add VHF capability to the DB4e, you can add a separate VHF high antenna - it does not have to be the VHF retrofit from Antennas Direct. The Antennacraft Y5713 is only $30 http://www.antennacraft.net/Antennas/AntennasVHF.html ... you can combine it with the UHF signal from the DB4e using a passive UVSJ http://www.solidsignal.com/pview.asp?p=uvsj or a preamp like the often-recommended RCA http://www.amazon.com/RCA-TVPRAMP1R-.../dp/B003P92D9Y
I am currently using a setup like this with a Y10713 above a DB8e on the same 10' pole, and an Antennacraft 10G221 preamp http://www.antennacraft.net/Antennas...mplifiers.html - works great.
As ADTech mentioned, you could also go with a large combo antenna, like the Antennacraft HBU type http://www.antennacraft.net/Antennas/AntennasHBU.html - here "large" means "long" ... the Y10713 has a 10' beam and the HBU55 has a 12' beam.
