Ok, I changed some things around. First off I forgot about a connection I had. There was a grounded terminal block (fem x fem) that my coax was running through between my amp and splitter. I removed the amp and the grounded terminal block connection and attached my antenna directly to my splitter input. In doing this my spotty HDFox 27 station's signal strength (as measured by the built in meter on the TV, however accurate that is?) went from reading a peak value of 30 to a value of 52, with a SNR (db) value of 21. I did not move my antenna, but I did completely eliminate the two connections. I think I will wait and see how this works out in the near future. As of now I've had the HDFox 27 station pixellation free for a few hours which is great!
My only question now is, should my antenna and or coax be grounded at any point. As of now there is no ground connection in my system outside of the two TVs.
