Old 1-Dec-2014, 8:51 PM   #5
Jake V
Do as AD Tech recommended. I'd aim the antenna at magnetic 242 to focus first on the Fox station, then adjust for the other stations as necessary (probably moving towards 258 degrees). Make sure that the antenna does not "look" through any metal and try to place it as far from metal as is possible (including any heating/ac duct work that might be in the floor of the attic or metal kitchen/bath vents).
You might also post the model number of picture of the antenna you are using for the experts to evaluate.
As Fox is your strongest signal, it should be pretty easy to get.
