Old 1-Dec-2014, 3:16 PM   #6
This is a situation where I typically recommend a ClearStream 2V without it's reflector. It will receive equally from the front and rear. All you really need to do is get it up in the air so it can "see" in both directions.
Your signals are strong enough that an attic location should work well. Just keep the antenna as far away from the metal stuff as reasonably possible so as to avoid blockages or reflections from the metal.
