Old 1-Dec-2014, 12:27 AM   #4
Jake V
If you have a satellite dish bracket/pole available, and it has a line of sight to both the north and the south (meaning the roof is not in the way facing one direction) then I would definitely use it. If the coax is still there and in good condition you can also re-use it. If there are splitters to different televisions it may or may not be usable (check the part number and post it).
Since the signals come from both north and south you'll need an antenna that can accept signals from both ends. I'll let others make a recommendation on that.
