Old 24-Nov-2014, 10:13 AM   #4
Stereocraig
Originally Posted by Rmlev View Post
Thanks for the suggestion, Jake, I'll try to do that. But I'm not clear why a bad connection or degraded coax would cause only those particular channels to drop out - the other VHF and the UHF channels are fine.
It sounds to be a matter of only the strongest channels overcoming whatever problem is sapping your signal and more channels will join the list, as the problem worsens.
Antennas really don't wear out, unless the rivets are extremely rusty, or loose.Replacing any coax, baluns, or splitters, is good advice.
You may want to use penetrating oil and a wire brush on the wing nut terminals.
If they are rusty, be careful not to snap them off.
