Old 22-Nov-2014, 4:25 AM   #141
Would those options not run into similar issues maybe with different objects or even the tree that ADTech spoke of. Just wondering your thoughts...
Probably not, because they would be using the same green lines as the eave mount, but just a little lower down on the rear of your house. Testing would tell you right away.
Just got another idea:
What would happen if you used the 5 ft mast section that you just bought to raise the C2V 5 ft higher on the satellite mount? No "ugly" tripod needed, but if it doesn't fit it wouldn't work.
