Old 20-Nov-2014, 11:35 PM   #122
mulliganman
The only things that come to mind are a sat dish with the legs or perhaps a tripod with an adjustable leg or a non-penetrating roof mount. That kind of tripod or non-penetrating mount would be harder to find and would not be able to straddle the ridge of your hip roof, either would have to move out onto a flat but sloped portion of the roof away from the sat dish mount.
I know you suggested possibly moving the 91XG up to where rabbit is suggested earlier in the thread. What advantage do you see by doing that? In the projection model map using the correct coordinates I don't see much change either in signal strength or conditions. Just wondering what improvements you are aware of that the model isn't showing (since I might be rather difficult to get that aimed precisely if being moved). It would also necessitate the use of the RCA preamp as well wouldn't it (because of the longer coax run to the entry of the attic)?
mulliganman is offline   Reply With Quote
