Old 20-Nov-2014, 9:11 PM   #120
mulliganman
Simply relocating the C2V from its current location is likely all you need to do. It "appears" that it's below the level of your neighbors home, but, only someone standing on the roof would be able to be certain. Your situation illustrates the pitfall of using an existing satellite mount without taking the TV antenna's different requirements into proper consideration.
If that existing dish mount has support "legs" for a larger 18x24 dish, it's sturdy enough to install an extension pipe into it an raises the C2V up. Depending on the specific mount, you might easily get 5-8' of additional elevation which might clear the neighbor's rooftop.
Barring that, simply moving the antenna to the rear edge of the garage roof, closer to your deck, may allow the C2V a relatively unobstructed field of view for a good distance towards Fordland. I'd even be inclined to try it on your deck if that gets you out from behind the neighboring house.
Let's say that dish doesn't have "legs" is there a mount that could be used in its current location that would give it enough height there to alleviate any issues? Just wanting to consider all the possibilities.
I am aware of the tree that you speak about. I haven't noticed any patterns with wind or rain but I will watch for it.
