Old 20-Nov-2014, 3:49 AM   #116
mulliganman
My last question for today has to do with alternative antennas. Since I will need to bring someone out (handyman?) to do this for me, I probably need to have an alternative antenna on hand if the error messages/multipath continues with the C2V. I have been researching some options which I will list below for feedback.
Channel Master CM 2016: http://www.channelmasterstore.com/Di..._p/cm-2016.htm
Winegard HD7694P: http://www.amazon.com/Winegard-HD769...negard+hd7694p
Antenna Craft HBU22: http://antennacraft.net/pdfs/HBU22_.pdf
Channel Master CM3016: http://www.channelmasterstore.com/Di..._p/cm-3016.htm
I can't find specs for it but this RCA gets good reviews: http://www.amazon.com/RCA-ANT751-Dur..._cd_ql_qh_dp_t
Primary consideration of course is performance, but size suitable for the mounting options and durability for weather extremes (here in MO we get quite a wide range of winter weather and other events). If I am overlooking a model, I'm willing to listen. I would like to get similar to better performance than what I am currently getting out of the C2V (again if I need to replace).
mulliganman is offline   Reply With Quote
