Old 18-Nov-2014, 2:14 AM   #101
mulliganman
Here are the 30 dB results (taken at 7:05 p.m. on 11-17):
Channel 3-1 52% signal strength, 21 dB SNR, Rs Corrected 0, RS Uncorrected 60
Channel 3-2 52% signal strength, 21 dB SNR, RS Corrected 0, RS Uncorrected 162
Channel 3-3 52% signal strength, 21 dB SNR, RS Corrected 0, RS Uncorrected 78
Channel 10-1 50% signal strength, 20 dB SNR, RS Corrected 0, RS Uncorrected 6
Channel 21-1 32% signal strength, 13 dB SNR, RS Corrected 0, RS Uncorrected 210944 and fluctuating by the second
Channel 21-2 32% signal strength, 13 dB SNR, RS Corrected 0, RS Uncorrected 88064 and fluctuating by the second
Channel 21-3 32% signal strength, 13 dB SNR, RS Corrected 0, RS Uncorrected 57344 and fluctuating by the second
Channel 27-1 57% signal strength, 23 dB SNR, RS Corrected 0, RS Uncorrected 0
Channel 33-1 35% signal strength, 14 dB SNR, RS Corrected 0, RS Uncorrected 35302 and fluctuating by the second
Channel 33-2 32% signal strength, 14 dB SNR, RS Corrected 0, RS Uncorrected 48538 and fluctuating by the second
Channel 33-3 35% signal strength, 14 dB SNR, RS Corrected 0, RS Uncorrected 417585 and fluctuating by the second
Channel 49-1 62% signal strength, 25 dB SNR, RS Corrected 0, RS Uncorrected 0
Channel 49-2 same as 49-1
