Old 16-Nov-2014, 9:20 PM   #88
mulliganman
Is it safe for me to assume that you have your 91XG and C2V on the satellite mount that is located where the teardrop indicator is located on the satellite view of your house? It looks like it is on the East side of your house, about half way back from the front.
I don't have a photo of your antennas, so I'm trying to picture in my mind if you have both antennas on the same mast, and which is on top. I looked at some other map images to try to see how high your antennas might be, but I couldn't tell. My concern is whether the signals coming from the NE for the C2V are able to clear the roof of the house that is East of your house, because when I turn on the green signal lines for the interactive map, they cross the peak of the roof of that house.
I've tried to upload some photos I took with my IPAD of the electrical system outside the house and the placement of the antennas. The pictures aren't the best but hopefully will do. The 91XG should be easy to make out and the C2V is just to the right of it in the photo.
