Old 15-Nov-2014, 4:17 AM   #81
mulliganman
Equipment like a tuner, a TV or an AC7 is expected to be grounded when in use to protect it from RF interference.
Your power strip does not have that provision.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
But this one does:
http://www.amazon.com/Tripp-Lite-TLP...SR8VY9F6CDQD8J
You can see the two coax connectors at the center of the strip. Using those connectors for your antenna coax might expose it to interference from the other equipment connected to the strip and there might be internal surge protection between the center conductor of the coax and the shield that can degrade the signal.
I'm sure I will have more questions but are you saying I need that power strip you linked instead of the one I am using?
