Old 15-Nov-2014, 1:04 AM   #78
Thank you for the 6 dB attenuator test with the Roamio DVR. Please try more attenuation when it is available. Start with 10, then 20, then 30, then 40, and then 50 dB.
Not to compare apples to oranges, but I remembered my Channel Master DVR+ had a signal quality diagnostic so I connected to it on the same TV and got 100% signal quality even on the stations that I got errors on from the Tivo diagnostic. Kind of interesting.
Yes, very interesting. What does that tell you? Are you able to make any conclusions based on the CM DVR+ test?
Now, please connect the antenna to the Panasonic TV and tell us about the reception quality as a viewer; never mind about errors. If there were uncorrected errors in the Panasonic, it would affect the reception quality.
