Old 14-Nov-2014, 4:13 AM   #13
ZippyTheChicken
I'll be happy to look in depth at your location, but I will require the precise GPS coordinates of your roof.
Sorry ADTech I don't feel comfortable with that
The TVFool Report is not even from my neighborhood its up the street a couple miles but if you can read the signals from that report you should be good to go because I live....
Between Dover Delaware and Middletown Delaware and the terrain here is both flat and very similar for a 20+ mile radius.
There are no hills .. there are no large obstructions other than homes which are 300 feet away in the direction I am pointing my antenna... no trees of any concern .. the area is flat and most of delaware is flat until you hit the last 25 miles before pennsylvania and even so its all graded pretty even from here to philly in relationship to the distance...
Signal gets that far from the tower and a rolling hill is not going to block signal.. its not like I am in West Virgina in a valley .. or even in a suburban community where there can be variations of hundreds of feet ...
Its just flat here and for a good 30 miles its flat to philly
and to baltimore its flat all the way there with the exception of water the signal will cross.. and south of me.. flat...
heh
anyway from Dover DE to Middletown DE.. pick a spot any spot .. pretty much gonna be the same especially since signals are 50+ miles away.
Thanks for your reply ADTech
ZippyTheChicken is offline   Reply With Quote
