[QUOTE=rabbit73;47796
Earlier you said:
I can understand how that might be difficult. Your basement TV is a 60-incher; it is a lot of work to move a large TV. That TV is a Panasonic VIERA TC-P60ST60, which is a nice TV with good reviews.
What I want you to do as a second test is to disconnect the antenna coax from the Roamio and connect it to the P60ST60 to see how it behaves with the same signals that were going to the Roamio. The results might give us a clue about what improvements can be made to your antenna system.
When I have more time, I will give you some more answers.[/QUOTE]
How should I do the comparison? When switching back to the Roamio go back into the Diagnostics menu to check Uncorrected Errors?
