Old 14-Nov-2014, 3:01 AM   #71
mulliganman
There are two tests that you can do to see if my theory has any merit.
The first test would be to get several 10 dB and 20 dB inline attenuators to add to your attenuator collection. Add more attenuation between the C2V and the AC7 and see what happens to the errors; never mind about the signal strength as long as there is enough left for the tuner to decode the signals for proper reception. You have plenty of NM available before you get down to 0 NM. And you have plenty of dBm Pwr before you get down to -83 dBm, which is where you will reach the "digital cliff.".
So I need clarification here. Are you saying to use enough attenuators to account for 10 or 20dB total? If you are suggesting something else can you link to where I bought from before what I would need?
I have one more 3dB attenuator left that if I would add to what is already in use would total 9dB. So far, the only channel's signal strength affected is 33-1, 33-2, and 33-3.
