Old 14-Nov-2014, 2:52 AM   #70
mulliganman
Don't give up yet, I still have some more ideas for you to try.
Thanks for the exact coordinates. I ran your FM fool report to see if there were any strong FM signals that might be causing interference. With FM fool there is no link like there is for tvfool reports. I deleted the numbers after the decimal point to protect you, even though the report only shows two digits after the decimal point. I also ran some tvfool reports at different heights, but I will not post them unless you give me permission to do it. They also have truncated coordinates, so the approx. coordinates are pretty far away from your exact location. This is your FM signal report:
It is okay to post the other tvfool reports if you think they will help. Let's just not try to reveal my exact location for the whole web to see.
mulliganman is offline   Reply With Quote
