Mast Pre-Amplifier Powering Options
Hi folks,
I am looking to buy a mast mounted pre-amp. I have the option of using a power injector which I believe sends DC voltage up to the mast mounted pre-amp through the same coax cable that the TV signal uses. The other option is to run a separate outdoor rated low voltage power cable up to the pre-amp.
What are the pros and cons of each option?
I am particularly interested in whether running power through the coax will have any degrading effects on my signal.
Thanks!
