Old 13-Nov-2014, 12:31 AM   #63
timgr
Originally Posted by mulliganman View Post
I've asked this a couple of times but haven't gotten any responses so I'll ask again. If I moved the 91XG to the peak of the 2nd story of my home, what equipment would I need for mounting it there. I'm hoping you may be able to answer after looking at the coordinates I gave you.
Are you asking about the mechanical process of mounting an antenna on the roof peak?
If so, you'll need some sort of mast and a way to support it. This could be a gable end bracket, a tripod, a chimney mount, or a ridge bracket with guy wires. Mostly it depends on your roof configuration and which method most appeals to you.
Look here for some ideas about mounting brackets - http://www.antennapartsoutlet.com/ - I've bought from them. The shipped fast and had reasonable shipping charges.
