Old 12-Nov-2014, 10:57 PM   #6
Tekcor1
Quick question, does the antenna get mounted so it is parallel to the ground? I'm assuming it does, but nothing states explicitly in the directions. Also, the splitter that is currently hooked up is a Signal Vision SV-V3G. Now that I'm looking at it it is probably not an amplifier because it doesn't plug in anywhere. Am I correct about that? It is wired to the grounding rod outside of the house.
Tekcor1 is offline   Reply With Quote
