You will find that the 91XG will outperform the 7698 on UHF (it has no expectation of VHF performance, use a separate VHF antenna for that). The 91XG has higher gain, greater F/B ratio, and a narrower beamwidth bay almost half.
You do realize the 7698 is 14' long, don't you?
Is that true? I have lots of dropout problems!
It's a lot more complicated than that. Perhaps it would be best if the reason for the dropouts was identified so that an solution might be investigated.
