It appears you may have some challenges.
You want the main networks.
CBS - 16 degrees and a strong UHF signal
FOX - 199 degrees & a weaker VHF Signal
NBC & ABC - 181 degrees & a weak UHF signals
Also a CBS @ 181 degrees, also weak UHF.
Hopefully others will be along to provide input. But if it were me, I would try a 91XG (UHF) @ 181 degrees along with a Y10-7-13 VHF antenna @199 degrees, combined with an RCA dual input amp. I'm not sure the VHF would have enough to be split 4 times though. It may be that you would get the better CBS station through the backside of the antenna, don't know. Otherwise higher gain amps on both fed through a USVJ bringing both signals together. (Power injectors for the amps between the antenna and the UVSJ), then split with a quality splitter.
Can't comment on the existing cabling.
