Old 9-Nov-2014, 10:17 PM   #59
mulliganman
Not a surprise. OTA signals constantly vary in strength, especially 1Edge and 2Edge signals.
It couldn't be from the attenuator because it was in the coax line from the other antenna.
Raising the 91XG as ADTech suggested might make 49 stronger.
KTKO-LP digital and KTKO-LP analog are both very weak. No surprise there either, because of their very negative NM numbers, based on your old report:
http://www.tvfool.com/?option=com_wr...d24362e8886d03
Good; that's what the attenuator was supposed to do.
How is 10.1 doing now?
10.1 continues to get sporadic RS Uncorrected Errors as well as 33-1 and 49-1. Nothing else seems to do that.
Oddly enough even with the attenuator, 33-1, 33-2, and 33-3 continue to be around 67% signal strength (which is what they are at after inserting the LNA 100 and before putting the 3 dB attenuator in the mix).
I don't mind losing the KRFT channels as there is nothing on there I watch anyway.
