Old 8-Nov-2014, 2:30 PM   #2
timgr
I'm having a hard time sorting out your complaint from the text. By 19 you mean real channel 11? That's a VHF high channel and you can't really compare it to real channel 25 (?), which is UHF, using your new antenna.
So maybe you are complaining that you get more stations with the new antenna, but some of the stations that you got with the old antenna (indoors?) no longer come in reliably. Still have the old antenna? Are there any new obstructions between the transmitting tower and the antenna at the new location? Trees, for example, are a much worse problem for UHF than VHF.
If you want to isolate the effect, I'd suggest a stepwise approach. Connect the old antenna to a long cable and see if you still get the channels in question at the old location in the house. Then take the old antenna up on the roof using the same cable and see if the old antenna still receives the stations that it did at the old location. Then connect the old antenna to the new feed cable and see if you lose any stations. Divide and conquer. This will help to determine if the differences in location or the differences in antenna, or something about the installation, are to blame.
This may help you when thinking about siting your new antenna - http://www.hdtvprimer.com/antennas/siting.html
