Old 7-Nov-2014, 8:53 PM   #58
before I left for work. 49-1 and 49-2 were down to 52% (22 SNR) on the signal strength menu (from the 67% after I first inserted the 3 dB attenuator).
Not a surprise. OTA signals constantly vary in strength, especially 1Edge and 2Edge signals.
Not sure if that was due to the attenuator or something else.
It couldn't be from the attenuator because it was in the coax line from the other antenna.
Raising the 91XG as ADTech suggested might make 49 stronger.
Some 8 dash channels I was getting dropped off (they may have been analog stations i am not sure).
KTKO-LP digital and KTKO-LP analog are both very weak. No surprise there either, because of their very negative NM numbers, based on your old report:
http://www.tvfool.com/?option=com_wr...d24362e8886d03
33-1, 33-2, and 33-3 had dropped a little in signal strength too but no signal errors.
Good; that's what the attenuator was supposed to do.
How is 10.1 doing now?
