Old 7-Nov-2014, 7:05 PM   #1
Canadianeh
Hi-VHF reception with Antennas Direct VHF Retrofit Kit??
Good afternoon,
Would it be a fruitless effort to try using the AD VHF retrofit kit on a DB4e to attempt to receive the following two High-VHF channels:
Phys. Ch / ID
12 - CFCF
13 - WVNY
TV Fool report: http://www.tvfool.com/?option=com_wr...d243ead23d645f
If it helps to know, I can receive 32 - WETK which is located on the same stick, reliably on a crappy 6" antenna that came with my Hauppauge 950Q. I also could receive 21 - CBMT (click Pending Applications to see on TVFool report) with the same antenna, which is located on the same tower as 12 CFCF. Both 12 and 13 are exactly 180 degrees off from each other.
If this is highly unlikely with VHF and my distances and NM, just be honest. I'd like to keep my antenna profiles down to a minimum, but strong enough to pick up the stations reliably.
My alternatives at this point is either the y5-7-13 or the DIY hourglass VHF loop.
Oh, lastly, does anyone know what the gain is using the AD VHF retrofit kit? I'd assume it's not very high :P
Thanks!
Canadianeh is offline   Reply With Quote
