Old 5-Nov-2014, 4:08 AM   #17
Nice photos.
You need to isolate the bad part of your system.
Divide and conquer.
I suggest you use the substitution method for troubleshooting your system.
Put together an antenna, preamp, downlead, and TV that work.
Then, substitute, one-by-one, each suspected part of your present bad system into the known good test system that works.
Yeah, I know it sounds like a lot of work. Any worse than what you are going through now?
