Old 4-Nov-2014, 6:20 AM   #39
The LNA100 isn't a "pre-amp", it's a "back of the set" type of amp without the capability of using a remotely located power inserter. It has to be powered locally (to the amp) from a wall-wart. I suggested it because it has a very low noise figure and a very good tolerance to strong signals, both characteristics that I've verified. Besides, it was already on hand!
Thanks for the correction.
I had remembered that he ordered the AC7 with power pass-thru and was concerned about the location of the splitter. As you correctly pointed out, the LNA 100 has an AC adapter, but it doesn't have a power inserter, so it can't be powered thru the AC7.
