Old 4-Nov-2014, 12:49 AM   #35
mulliganman
Before I answer your last question, I need to be sure that I understand your present new setup that is working the best so far. Is there anything between the AC7 and the input of the Roamio?
AC7 > coax ? ft > input of Roamio > TV
or in greater detail:
Code:
91XG > LNA 100 >
                  AC7 > Roamio > TV
           C2V >
Are you powering the preamp thru the AC7, or locally at the preamp location?
Your drawing appears to show the current configuration. The coax from the 91XG connects to the Winegard LNA 100 and from there into the single channel input of the AC7 combiner. The C2V coax connects directly to the other input of the AC7. The output to the Roamio TV is being connected with these F barrel connectors:http://www.amazon.com/10pcs-Frequenc...=vglnkc3181-20
mulliganman is offline   Reply With Quote
