Old 3-Nov-2014, 7:14 PM   #32
mulliganman
Try the two tuner side-by-side comparison I suggested to see if it happens on both tuners.
Is this the comparison you are suggesting (see bold):
OTA signals are constantly changing. If you want a real-time side-by-side comparison between two tuners, you can insert a splitter after the antenna system to feed the Roamio tuner and a TV, and feed a second TV connected directly to the splitter.
If something bad happens as shown on the TV connected to the Roamio tuner, you can see if it also happens to the TV connected directly to the splitter.
Is there any risk damaging a TV tuner sending that much signal to a single tuner? So you are taking about inserting a two out splitter after the output of my AC7 combiner (one output to the Roamio and one output to a 2nd televison)? If so, I can try but it may be tough to catch since I don't have 2 TV's in the same room.
mulliganman is offline   Reply With Quote
