Old 1-Nov-2014, 9:10 PM   #19
mulliganman
Just wondering about FOX. Does it behave better when the 91XG is connected directly to the TV instead of your present setup?
Just to be clear, you are saying how is Fox if the coax from the 91XG is just connected to the basement television (minus the Roamio)?
I haven't looked at that in a while but I assume it is probably similar or slightly better since we are only dealing with 1 tuner as opposed to 4.
If I need to connect it that way, I can. i will just need to do at a time when the spouse isn't trying to watch TV because I don't believe the Minis will get a TV signal if the Roamio isn't getting the feed directly.
mulliganman is offline   Reply With Quote
