Old 31-Oct-2014, 1:58 PM   #11
johnodon
Thx Tim. That is exactly what I was planning on doing when I get home from work...
Get the EA up in the attic and point it at 36degT.
Combine it with the ANT751 using a splitter/combiner. The one I actually have is teh same one you linked above.
Also, a couple questions about placement/runs...
1. RE: the DB8E panels....do I need to get the EA as far away from the ANT751 as possible, or, a specific distance away (like the DB8E panels), or, it doesn't matter?
2. I believe that the runs from each antenna to the combiner need to be the same length, correct?
If everything turns out hunky dory, I'll just leave it and add the CS600 to the mix with the RCA preamp. Heck, this would save me a nice chunk of change as I was starting to eyeball the DB8E and planned on asking about it.
Thx for the advice!
John
johnodon is offline   Reply With Quote
