Old 30-Oct-2014, 11:53 PM   #9
johnodon
I'd suggest a simple UHF Yagi. Good, focused beam with extremely sharp nulls at 90°. Plus, they're long but not very tall, a good choice for a height-limited attic as compared to a 4 or 8 bay UHF antenna. Actually, I'd suggest getting two of the same model and make a proper 90° UHF-only array (two equal length cables plus a reversed splitter), then combine with the CS600 using the RCA amp. The 751 gets "re-gifted" to someone else.
When the angles are 90°, combining with a reversed simple splitter has about the best odds of working, but it's still a crap shoot, especially in an attic, due to signal reflections that still might make it into the undesired antenna. You will loose about 6 dB of signal from each antenna so keep that in mind. Worst case is that you'd need a custom, single channel combiner which would likely run $125-150 which would limit combining losses to less than a dB or so.
I think this may be my best option...
I hooked up the cheap, little DB2 antenna to my bedroom TV. All I did was sit it on my bed and pointed it to 36degT and scanned. To my utter amazement, I pulled in everything that Allentown has to offer: RCH9, RCH38, RCH39 and RCH69. Better yet, I got the only channel I really cared about (RCH46) @ 100% signal.
However, I also was still able to receive a LOT of the Philly channels even though I was pointed directly at Allentown. I'm going to assume that this could cause me some issues. So, I think using 2x UHF YAGI's (one pointed at 36degT and one pointed at 123degT) + 1x CS600 (pointed at 123degT) is the way to go for me. This way I'm assuming I can combine the two UHF YAGIS with the reversed splitter and feed that single line + the single line from the CS600 into the pre-amp. Correct?
@ADTech...can you recommend a UHF YAGI I could pair with the CS600 and would best suit my needs? Maybe the AntennaCraft MXU47 or similar?
Thanks for all of the great advice!
John
johnodon is offline   Reply With Quote
