Old 28-Oct-2014, 4:36 AM   #3
atlantis43
The signals in your location are too strong for you to use an amplified antenna. Find your old unamplified rabbit ears.
Your rooftop antenna cannot be aimed at the signals from the Empire State Building and 50.1 and 66.1 at the same time. I'd assume that it would work if it were aimed toward New Jersey instead of Manhatten. I don't know why 13.1 isn't working.
Just wondering about the 'strong' signals, since even with amplifier off, I get the same audio & video interference whenever boats pass by, whether they be small tugboats or massive cruise ships. The larger the ship, the greater the interference. Is this due to signal strength, or other types of interference?
Also, do you think that 13.1 may improve if they ever switch broadcast to the Freedom Tower?
atlantis43 is offline   Reply With Quote
