WTSP 10, WTVT 12 and WGFL 28 are -17, -18 and -19 dB NM. I'd put those in the "impossible" category at the current antenna height.
It should be possible to pick up WOGX 31 at -0.3 dB NM if you point your 91XG at it. But you'll likely have to point right at it and a preamp at the antenna should help. But it's very weak at that height.
Can you go a lot higher? Run your report again with a better antenna height.
