Old 25-Oct-2014, 2:45 AM   #9
M.Unit
Originally Posted by timgr View Post
Stucco could be a problem because of the wire mesh embedded in it. Aiming through the roof may be ok. If it's a big attic, move the antenna around in it if it does not work perfectly at first.
A red ceramic tile roof? This does not sound promising. Steel and stone.
It is concrete roof tile with wood underneath. Is that bad?
As for the stucco, the attic thankfully isnt surrounded by it. I would definitely point it upwards and out through the side of the roof....
The RCA ant751 says it's 40 miles....the Clearstream 2V says 50+ miles
I'm assuming the Clearstream should work better?
M.Unit is offline   Reply With Quote
