Thanks Jake V!
So as for our roof and siding - we live in the land of stucco here in Arizona and our roof is standard wood with barrel roof tile on top. There's no metal sheeting or radiant barrier or anything like that (we have spray foam insulation). There are no obstructions around us either.
So we used to have the RCA ant751 but it was outdoor mounted about 8-9ft from the ground...and we didnt use any amplified splitters or pre-amps or anything like that. Got fantastic reception of all the channels. We're essentially within the same neighborhood (same distance from towers)...you think the RCA is worth trying in the attic or should I just skip it and go straight to the Clearstream 2V in the attic? Roof is not an option at this point...and my husband wants to keep it at or below $100.
Thanks again for the advice!
