Old 24-Oct-2014, 9:54 PM   #5
Jake V
You have a favorable report.
You should receive a full slate of the Phoenix channels with either the RCA ANT751 or Clearstream 2V aimed at 260 degrees on a compass if mounted on the roof. Attics are strange places. Sometime an antenna works fine in an attic and sometimes it does not. You just have to try. Others might comment if you tell them what your roof and siding is made of.
You also have possibilities if you want some of the Tucson stations. Maybe a DB-8e with one panel at 260 degrees and the other at 129 degrees. You might need a separate VHF antenna the high VHF channels (8 & 12).
Wait for others to comment (there are some real experts participating here).
